[BRUDER] Mon Bruder Cat Delta Loader
Caterpilar
Message par Caterpilar »
Comme j'écrit pas bien français, je vais le faire en englais si ça ne pose pas de problème :)
I am planning to do a conversion of the Excavator shortly but as I am new in RC land, I thought to try first with something smaller and easier. So my choice went to the Bruder Delta Loader.
Before starting to rip the toy apart and start the conversion I spent a lot of time searching the forum for pioneers who did do the conversion already. After looking several builds, I decided to go ahead deal with the problems on a case by case basis. I learnt a lot and am confident to start on the next Bruder conversion.
I have completed the conversion in a timespan of 2 weeks (few hours in the evening and weekends). The job was more difficult than expected. Taking the toy apart required a lot of patience.
It took a while before all my parts arrived (due to a lack of decent RC stores in Belgium, I had to order most of the stuff from the internet).
Here are a few video's
first test: http://www.youtube.com/watch?v=6HZS5L8W0Hk
the delta loader in operation. http://www.youtube.com/watch?v=s-3_5Qq-SZw
I am not using it in sand as yet as I am not sure if I keep it or sell it. My goal is to make the excavator.
Koen
lucas
Numéro de département : 81
Re: Mon Bruder Cat Delta Loader
Message par lucas »
Hello, this is a very nice project :up: but I want to know the lift system because yon don't explain him :(
I think it's servo but I am not sure
The excavator works very well, good job :up: :up:
LUCAS
EXC en cours
No problems guy for english.
Thanks for yous explains. :D :up:
We are a lot of peoples to wait the rest of your futur chalange :banane: :respect:
Message par antoine22 »
super projet hate de voir la suite :respect:
Caterpilar
lucas a écrit :Hello, this is a very nice project :up: but I want to know the lift system because yon don't explain him :(
thats right lucas. the lift system for the main arm is a high torq servo. For the bucket i am using 2 small metal gear servo's back-to-back
-- Thu May 10, 2012 11:21 pm --
I used a Tamiya gearbox but removed the tamiya motors and replaced them with better slot car motors
Hitec high torq servo for the main arm
2 hitec metal gear servos for the bucket curl
sabertooth controller
separate 5v 5amps bec
controller for the light (high power leds)
battery
spektrum 6ch 2.4GHz receiver
it all fits well in the model but there is no more space inside (thats why I had to use a small controller for the light instead of a relays.
camion
Message par camion »
hello this is a great project! I will be realized the little red shovel bruder! again EST Good work!
man 6x4
Remorque plateau
chariot linde carson
very nice :up:
I love this machine :banane:
Julien
Message par Julien »
Hello caterpilar, nice work on the bruder, and only in two weeks ! i'm jealous as i started mine more than 2 months ago and it's still open and collecting dust on my desk :lol:
i like the plate holding bucket's servos and how you linked the servo for the arm. feel free to post more photos of what's inside ;)
thanks for sharing your work, that will help me on my conversion :up:
Caterpilar
Julien a écrit :Hello caterpilar, nice work on the bruder, and only in two weeks ! i'm jealous as i started mine more than 2 months ago and it's still open and collecting dust on my desk :lol:
Merci Julien.
Voila encore qq photos
bon WE
christiannoel
Message par christiannoel »
Bonjour Carerpilar
Trés bien ton montage et en plus ça fonctionne, sur le mien le sabertooth ne suis pas ,probablement à cause du servos du bras ,mais toi lequel as tu utilisé ? sur la photo je ne vois pas la marque et le type
Caterpilar
Salut Christian
I used the Hitec HS-7955TG for the main arm. Which sabertooth are you using? It should work with any servo. Do you use the BEC from the Sabertooth?
christiannoel
Yes, i am using the same Sabertooth as you do, the Sabertooth 2X 5 RC (the same as Julien too),and i use the BEC from the Sabertooth also.
Caterpilar
Ok. That's why it doesn't work. You should not use the BEC from the sabertooth but a seperate BEC with higher Amp.
camionrc35
Numéro de département : 35
Message par camionrc35 »
?ON COMPRENDS RIEN????????? :x :x
FORGETTE
Message par FORGETTE »
Hello
THANK YOU FOR THE REPORT .it WOULD BE EFFECTIVELY PLEASANT THAT THERE ARE SOME EXPLANATIONS IN FRENCH BECAUSE EVERYBODY DOES NOT MASTER ENGLISH PERFECTLY
MERCI POUR LE REPORTAGE .IL SERAIT EFFECTIVEMENT AGREABLE QU'IL Y AIT QUELQUES EXPLICATIONS EN FRANCAIS CAR TOUT LE MONDE NE MAITRISE PAS L'ANGLAIS PARFAITEMENT
christian
Christian
Revenir à « Chargeur »
