in those post i'll show the works of years working, is tired but it´s funny
i have not finish the 3D model yet but i want to machining something! ok, i´ll post a lot of photo and video,as note, and all my major machines are DIY
ok, here we go!
the first piece is a link of the chain
i have to machining 196 links, a preview model
a video of the machining (right link)
[bbvideo=853,480]https://youtu.be/7DmqKonu2IE[/bbvideo]
[bbvideo=853,480]https://youtu.be/7Rv3OzudaCM[/bbvideo]
and the left link
[bbvideo=853,480]https://youtu.be/P0JbwqnjaF8[/bbvideo]
the traction wheel:
i use a cycloid gear inside the wheel cube with a relation on 1:100 and i turn this shaft using a timing pulley with a 1:6 relation --> final relation 1:600
sectional cut
videos
[bbvideo=560,315]https://youtu.be/vtx9vAy3h9I[/bbvideo]
[bbvideo=560,315]https://youtu.be/jrk4c-XzaZA[/bbvideo]
ok, this is the current status , i need to make the pads for the chain, at the first place i thought to machining it, but i have to rotate them in the mill many times, too boring, i had to learn another technique, lost wax casting
the first cast (bronze)
regards
(obviously these are not the final screws)
