Pelle Hydraulique liebherr 984R 1:14
TESSEN
Pays : E
Has thanked : 6 times
Message par TESSEN »
Hi,in the first place and after the presentation of myself in the correct section, sorry to write in english, if anyone want to write can do it in french, ok, the important part, the pictures
in those post i'll show the works of years working, is tired but it´s funny :)
i have not finish the 3D model yet but i want to machining something! ok, i´ll post a lot of photo and video,as note, and all my major machines are DIY
ok, here we go!
the first piece is a link of the chain
i have to machining 196 links, a preview model
a video of the machining (right link)
[bbvideo=853,480]https://youtu.be/7DmqKonu2IE[/bbvideo]
[bbvideo=853,480]https://youtu.be/7Rv3OzudaCM[/bbvideo]
and the left link
[bbvideo=853,480]https://youtu.be/P0JbwqnjaF8[/bbvideo]
the traction wheel:
i use a cycloid gear inside the wheel cube with a relation on 1:100 and i turn this shaft using a timing pulley with a 1:6 relation --> final relation 1:600
sectional cut
videos
[bbvideo=560,315]https://youtu.be/vtx9vAy3h9I[/bbvideo]
[bbvideo=560,315]https://youtu.be/jrk4c-XzaZA[/bbvideo]
ok, this is the current status , i need to make the pads for the chain, at the first place i thought to machining it, but i have to rotate them in the mill many times, too boring, i had to learn another technique, lost wax casting
the first cast (bronze)
regards
Dernière modification par TESSEN le 17 févr. 2018, 20:13, modifié 3 fois.
Re: Pelle Hydraulique liebherr 984R 1:14
Really nice work, the parts are beautiful :up:
You make them with a CNC?
TESSEN
Pays : E
Hi cc38150, thanks, yes, the most parts are made with a self made cnc machinery
more photos
Image (obviously these are not the final screws)
the second cast (brass)
the third cast (brass)
the third casting was better, i made the pads that i needed and i did a test casting, to saw that this technique is able
the wax test cast
the final cast
my pads cast
Dernière modification par TESSEN le 20 nov. 2017, 10:38, modifié 1 fois.
tortle
Numéro de département : 13
Message par tortle »
Beautiful work tessen
MAILLOY
Numéro de département : 974
Has thanked : 337 times
Been thanked : 171 times
Message par MAILLOY »
nice, goob job :up: love this :bave:
ZipZip
Has thanked : 9 times
Been thanked : 7 times
Message par ZipZip »
Great job :respect: :up:
Liebherr L574 - 7,2kg Vendu
BELL B50D Fumotec
Chargeur 870K
TESSEN
Pays : E
thanks guys! :up:
Well, these are the most important pieces, now it make a dotted and drill (which has no mystery), one thing that if it could be funny / curious, are the nuts with hex screws that hold the pads to the chain, finally i did it with my cnc router, the pieces were made in brass, nuts are threaded to M2 and measure 3x3mm, totaling 405 nuts, machined with a 1.5mm drill (the champion of end mills)
a little video of the machining
[bbvideo=853,480]https://youtu.be/NHkC2UHnynI[/bbvideo]
and finally .. I could assemble the track
more photos, this is the time of the hubcaps for the traction wheel, made of aluminum
the master piece is made in 2 pieces, one milling and the other are made using laser engraving
after that, both are join
the mold and the wax copies
the result of the casting
salu2!
Dernière modification par TESSEN le 17 févr. 2018, 20:15, modifié 2 fois.
louloubenz
Numéro de département : 5
Has thanked : 16 times
Been thanked : 53 times
Message par louloubenz »
Very beautufull job :respect: :bave:
Bartste
Has thanked : 58 times
Been thanked : 230 times
Message par Bartste »
Good job ! Thanks for sharing.
TESSEN
Pays : E
thanks for comments :up:
more advanced, the lower structure, all stainless steel 3 mm and 1.5mm
the following photos correspond to the lost wax casting of pieces for support and guides rollers on tracks
and a pair of test of my future valves (for the moment, prototype)
https://www.youtube.com/watch?v=ACX_2GJdTNQ
https://www.youtube.com/watch?v=-big2h1tJiE
salu2! (best regards)
Dernière modification par TESSEN le 20 nov. 2017, 10:40, modifié 1 fois.
Goliath
Has thanked : 807 times
Been thanked : 304 times
Message par Goliath »
Good job!!! :up: :up: :up: :up:
CATER PILLAR
Has thanked : 18 times
Been thanked : 27 times
Message par CATER PILLAR »
NICE ,very NICE
TESSEN
Pays : E
thanks to all
and the latest advances
Dernière modification par TESSEN le 20 nov. 2017, 10:41, modifié 1 fois.
crocblanc01
Numéro de département : 57
Message par crocblanc01 »
Very good job
Can you give us the weight of the base
Envoyé de mon PLK-L01 en utilisant Tapatalk
TESSEN
Pays : E
thanks, i don't know what part you refer, but all the lower superstructure weighs about 15 Kg
the last photos and one test video
[bbvideo=853,480]https://youtu.be/ZSXQkJDTfbQ[/bbvideo]
regards
Dernière modification par TESSEN le 17 févr. 2018, 20:16, modifié 2 fois.
Revenir à « Pelle »
